Nother dead chonda
A quick internet search shows a Champion RJ19LM spark plug as being a direct fit. Other than that, I'd pull the 'heater box' off, take that carb off, carefully remove the bowl and clean it up. Like Courier says MMO, Seafoam, Lucas, etc..etc.. can work, but I've never seen a fuel add bring an engine back to life that won't start. Little finicky issues yes, they can work.
Joel
Pull the plug, spray a little carb cleaner into the plug hole, then reinstall the plug and wire. Give it a tug to see if it kicks. If not, put your thumb over the plug hole and you probably won't have any compression. It's a racket. The head gasket blows, then they sell you a whole $45 kit cause you can't just buy the head gasket. If the head bolts are loose, please, please don't torque them down too hard...they will break right off.
Be very careful with this procedure. Too much liquid can cause hydraulic lock, where there is no air to compress, only liquid. Since liquids are incompressible, you can bend/break a connecting rod, wrist pin, etc.
Originally Posted By: BigCahuna
Does that motor have a low oil shut off feature? may just need some oil to fire it up.,,
Thats right!! I forgot all about that! It happened to me once after changing the oil. I dont know why it has a red light on it? Their`s no battery (to light the light) to let you know whats going on after it shuts down.
My 6.5 HP Chonda manual says the following for spark plugs:
Maybe that will help...
thanks,
ben
Originally Posted By: Maritime Storm
In my area the B6ES is hard to come by, that's why I use Champions RN11YC4
If you don't have a CTC or NAPA nearby, try a motorcycle/skidoo/outboard motor shop for spark plugs.
That B6ES/BR6ES is a very common plug. A BR6ES is the same thing with a resistor. I doubt the resistor will have a negative effect on engine operation.
What's a good torque setting for a Honda/Chonda head bolt? I have a good torque wrench but no service manual.
BTW, I second whoever said to use some Chevron Techron in the fuel. I've had a Honda engine that sat over the winter months this year that would not start easily and when it did start it surged quite a bit. It's a 10 year old engine/mower and this is the first year that I've had this problem (usually starts on the 2nd or 3rd pull after sitting for the few winter months we have in my part of the county). This year was a problem though. After I got it started and it was running it was surging and would not come up to full rpms. I opened the gas cap while running and poured in a couple of table spoons of Techron. Absolutely amazing. Within 20 seconds the engine stopped surging and ran beautifully. Never had a bottle of anything fix an engine so well. I suspect that the last tank of gasoline has a good dose of ethanol in it and that caused gumming problems (even though I thought I ran the carb dry before putting it away). If the engine won't crank at all you may not have such good luck because you might not actually be able to get the Techron where it is needed. I'd pour some in the tank and crank on it for a while then walk away for a day and try again.
Like I said earlier in this post, looking for torque setting for Honda/Chonda head bolts if anyone has good info.
Thanks,
Scott
Rudolphna - Did you ever find out what was going on with the Chonda? I'm interested. I worked on one the other day that had sat dry for 2 years. The carb was clean looking, but pieces of it crumbled while I was trying to take it apart. Ah Chonda! Bless you!
Not yet. I'm betting it's the exact same problem I was having with the lawnmower, because it's doing almost exactly the same thing, only the chonda isn't starting at all.
