Non-Stink Iron-X
OH
The odor of these products has been talked about but I remember one being discussed that actually has a pleasant scent to it. But now I can't remember which one it is. I did send an email to Autogeek and received a reply. It's less stinky(rotten egg) but again I thought there was one that actually had a pleasant scent to it. Like pepper mint or something. Report back if you know. Of course a less stink product is better than a full stink one. Below is the answer to my email:
Hello Matt, I would recommend using Dodo Juice's Iron Remover. It does not have the strong smell that Iron X does but works just as well. http://www.autogeek.net/dodo-juice-ferrous-dueller.html
I can only imagine how bad the smell of the others is considering how some have described it. I have a bottle of Auto Finesse Iron Out which should be arriving tomorrow. I'm looking forward to trying it on the MDX.
You may need a respirator from the description of it.
Plus what areas to apply it on? I would think the lower half only and maybe the trunk since I've seen DD put it on there. Skip the roof and hood since I haven't noticed any rail dust on those areas.
Horizontal surfaces are especially prone to collecting the rust -- seen photos on detailing sites where they're fairly liberal with application to the roof, hood, and trunk. Rear bumper is a big spot too since the "vacuum" behind the car tends to draw particles to it.
Yes, I noticed the back hatch area on the Matrix gets a ton of rail dust on it. Just as much as the sides of the car. Plus the rear lip area of the roof gets hit.
Interesting. Have a good link?
Not in my experience with two white cars. It's almost all on the lower half and those surfaces are vertical. When you look at the Detailer's Domain write-ups most of the effort is concentrated there as well.
I don't have any links handy, but if you Google for "detailers domain iron x" or something like that you'll see what I mean. They tend to just spray the whole car, or even use the special car soap that has it.
I always apply it to the entire car, but most of the build-up seems to be concentrated on the horizontal panels (trunk lid, roof and hood).
The more contaminants that you can remove via Iron-X, the less that you will have to remove through claying. And that means less chance of marring.
I've heard that none of the Iron-X alternatives work as well as the real Iron-X Paste, fwiw.
