Non-Detergent Non-Synthetic 20w and 30w Oil - What brands and Where to Purchase
Midwest
I have a two HP twin cylinder air compressor (25 year old Sears) and a 3200psi/4GPM AR Pressure washer Pump that I need to get 20W (air compressor) and 30W (pressure washer pump) non-detergent oil. My useage on both units is less than 10 hours per year so suspect non-synthetic oil would be acceptable.
Question is: what brands non-detergent non-synthetic oils are still available and where can I purchase them from. The automotive stores seem to no longer cary non-detergent oils. Do we have to use the specially labled pump oils now to get non-detergent oils. Would old piston engine aircraft oil be acceptble as it was non-detergent AD oil?
Thanks Wayne
The Citgo/Mystik line of non-detergent oils are carried at Farm & Fleet stores in WI-IA-ILL.
The Mstik line of non-detergent oils are SB rated and are available in 10W, 20W & 30 SAE viscosities.
Typically, the Accel SA rated oils are found at Walmart - Don't know if a 10W is available.
