I don't know, but it certainly kicks buttock in terms of full-flow filtration. If I recall correctly, the test dust for the multiple-pass test is a mix of 10-20 micron particles. With a multiple pass result of 98%, and a single pass result of 99.7%, it's basically removing almost all 10 micron particles. That's excellent full-flow filtration by any definition. Without commenting on the test methodology, the lowest numbers I've heard associated with Mobil 1 is 10 microns, and 8 microns for AC Ultraguard. So the PureOne is right up there. And although this is open to debate, I'm of the opinion that the PureOne's "packed" pleats still leave more than sufficient room for oil flow -- one doesn't need a quarter-inch between pleats for oil to permeate the media. Although Purolator doesn't release PureOne media area spec's, I suspect they're fairly high compared to the competition, as was the case in the mini-Mopar study (400 sq in for PureOne, versus 360 for STP, 351 for Mobil 1, and 349 for Wix). And more media, in general, assists flow capacity.
