My 2005 Pontiac Grand AM started to make some noise ONLY when turning left. The noise is somewhat clunky like something is loose and touches something else.
The noise is intermittent and doesn't seem to have a pattern. However, most of the times, it occurs when I make a left turn and the road is bumpy. There is no noise at all if turning right or going straight.
I had the right outer tie rod replaced and that didn't seem to be the culprit.
I checked brakes and they looked fine. Struts seem OK, too, as they don't make noise when going over speed bumps.
What else could it be ? TIA.
