I have a warbling/groaning type of noise in the AC system in my Dakota. The noise is not present when the heater is in use, only when the AC is on. Is it possible to get an air bubble or air pocket in the AC when the AC is evacuated and recharged? I had that done after an accident and I have had this noise ever since. The compressor is original but the body shop replaced the condensor and the receiver-drier, the radiator and the fan along with some front body parts after I hit a deer on the interstate. I am thinking maybe they didn't pull enough vaccuum when they did the AC recharge and that is why I have this noise. The noise is only audible from inside the cab; when you open the hood there are no abnormal noises from the AC compressor or other AC parts. The noise is only present when the compressor cycles. The fan and temperature control both work fine and the AC is ice cold. I am stumped and appreciate any help.
Thanks,
Thanks,
