Hey Everyone Heres an update:
I dont know what wacky thing is wrong with this heater system, but I do know that I found out that the heater core does work and is not clogged.
When Thermostat (temp control) knob is turned to COLD, I get HEAT on the passsenger side foot compartment (hot heat like a blow drier). It does not matter what position the vents are turned to - When selector is on COLD I get HEAT on the passenger side foot compartment but I COLD air everywhere else.
When I turn the Thermostat (temp Control) knob to Hot I get cold air everywhere no matter what the vents are selected to and in the passenger side foot compartment I get WARM (not hot) air and everywhere else is cold.
BOTH Heater hoses are HOT Inlet and Outlet when selector is on hot, When selector is on COLD only one heater hose inlet is hot and the outlet is warm (if that matters)
All the motors for electrical control to change vent position and temperature have been changed and heater core has been flushed clear. I think if it was the heater core I wouldnt get any heat at all correct?
I have a feeling that maybe the motors for the vents or temp have been installed reversed? (For example: when turn to cold the vents go hot and vise versa)
One last thing is when I have the ac on, on a humid hot day it blows cool say about 70 degrees or a little higher but struggles and eats up my gas because it works so hard. On a cool day or decent day the AC blows cold. Either way everytime the AC is on I get a leak on the passenger side foot compartment.
When I attempt to put the heat on I do not get any leaks at all.
When I turn the car off whether it had the cold air or warm air on I get a hissing sound from the passenger side foot area.
Everything seems to lead to that point and I noticed that the passenger side air duct by the foot area used to be covered up with tape.
Im sorry I have repeated myself, but I just spent 45 minutes messing with it trying to brain storm why I do not have heat.
Good thing is, if it is just the blend door, I can reach up through the duct on the drivers side and force it open or closed. If it is the heater core, dash needs to come out.
On drivers side the motor that opens and closes the blend door, moves and turns the internals but I could hear a hiss like the door snapped off or is stripped and isnt moving but you can hear air getting around it, but If I apply pressure with my hand the hiss goes away and the air gets slightly warmer.
What gives? any takers?
Thanks guys
