No 5w20 A5/B5 oil?
WA
Hey bitog.
I noticed that none of the major oil brands have 5w20 A5/B5 oil while all of the 5w30 do have A5/B5.
Knowing A5/B5 helps with fuel dilution, I hoped to grab an A5/B5 5w20 for the next scheduled dealer's maintenance and couldnt find one.
Can anyone explain why a5 is only available in 5w30 flavor?
A5/B5 requires HTHS of at least 2.9, which no 0 or 5w20 can meet.
A1/B1 had an exemption for 0w20 and 5w20, where the minimum was 2.6, but ACEA dropped A1/B1 from the latest sequence and replaced it with C5.
Use a 5w30 A5/B5
Originally Posted by Marco620
Redline Oil 0w20 or 5w20 in A5/B5 AND HTHs 2.9 and 3.0
Except of course, Redline is not A5/B5, only "recommended for". Considering that the ACEA doesn't certify or approve anything (it is self-determined) it is especially amusing that they don't even try and make you think that it is A5/B5. but still use the recommended language.
In the US , only off the shelf Pennzoil Platinum 5w30 and Mobil 1 5W30 list A5/B5 rating ...Castrol , Valvoline and Quaker State to the best of my knowledge do not .
It's not possible for a 5w20 to meet A5/B5 because it requires HTHS at least 2.9, which is impossible with a 20.
ACEA dropped A1/B1 in 2016
There is a new ACEA C5, which has a provision for 5w20.
