I bought a nissan quest with 98k miles on it. I bought it really cheap because it had the bad timing chain guides. I spent 2K at the dealership to get them changed. After they changed it and the oil, which i assume is nissan 5w30. Everything seemed perfect. After getting it home and looking over tons of posts i decided that i was going to run rotella 5w40 in it. When i startup the van and it is cold out, apx 50F or less, it makes a lot of noise in the cam chain area for a few minutes until its warmed up a little. After it is warm, the noise is gone and it is silent as a mouse. The startup up noise is significant. It almost sounds like a bad bearing. Not really clattering or anything. Is this normal for these engines? I have read they are sensitive to viscosity but i would think 5w40 would be fine in 40F weather.
