Nissan Maxima VIAS/Power Valve Default Behavior
TN
Anyone know how this is supposed to work? I've heard a few versions.
When the car is off, my VIAS/Power Valve is in the open position. I define open as the valve is sitting perpendicular to the ground => | allowing the cavity in which the VIAS resides to be open to both parts of the intake.
Now, at a certain RPM the valve is supposed to close (parallel to the ground) => -- causing only the top portion of in the intake to be receiving incoming air.
Should the VIAS be in -- or | at low RPM (below 3000)?
Last night, I put a string in the arm so that if it closed (--) it would drop the string. This morning, driving to work, I went up from 60 MPH to 75 MPH and reached 3100 RPM. The VIAS never moved though.
OK, found this on maxima.org (for anyone interested)
Quote:
On the 02-03, the VIAS has its default position as open, but is closed via vacuum and ECM control from 1800-3600 rpm, so when any part of that mechanism is faulty, the valve remains open throughout the RPM band.
http://forums.maxima.org/5th-generation-maxima-2000-2003/372156-2k2-vias.html
Now just need to check which part is not allowing it to close (actuator, solenoid or vaccuum cannister).
