The subject title gives it away, but I'll share the story...
Was looking for a cheap, basic trimmer awhile back; no particular requirements other than it be marketed as a "brushcutter" (not doing that, but if it has the performance for such heavy usage, it should be strong enough for tall/heavy grass) and have low/high speed carb adjustment screws (so as to not be locked into garbage OE setup).
Lowes was having a sale on the Troy-Bilt TB32 EC, and the reviews were generally positive, so went ahead with the purchase.
Ended up being rather disappointed; took forever to warm-up, used a bunch of fuel and completely gutless. Fine for short stuff, but unless the trimmer line was kept very short, it'd bog-down and be next to useless in taller/heavier grass. Tried adjustments, but nothing worked.
Spark plug that came in it had no name and just a number; looked fine though, with no deposit accumulation and proper gap. Wasn't expecting much difference, but went ahead and cross-referenced it over to the NGK Pro-V (these are their OPE plugs). No one carried it locally, so went ahead and ordered from Amazon ($6/free shipping). Upon arrival, I made no adjustments whatsoever (same gas, same carb settings, etc.) and just installed the new plug.
All I can say is...WOW!!!! This thing is like a completely different trimmer. Ready to go almost instantly on start-up, uses significantly less fuel, and seems like it has twice the power as before. Now, it has no problem whatsoever turning much more line, and cuts through heavier grass without issue.
In other words, if your OPE isn't performing like you think it should (mower, trimmer, blower, etc.) and you've looked at everything else, give these plugs a try!
