1. Can the pre-oiler draw oil from the port where oil pressure sensor resides? I already have a sandwitch adaptor installed for Frantz oil bypass filter which has only one outlet port.
2. The Accusump web site indicates its products use 1/2" NTP fitting, which is quite large. Will it function well if a reduction adaptor is used to connect the pre-oiler to the oil pressure sensor port? I understand the pre-oiling process might take longer due to smaller port.
3. Does the mechanical oil pressure gauge on the Accusump actually reflect the actual engine oil pressure? That is, does it double as oil pressure gauge?
