To all a thank you ahead of time for taking the time to respond!
I am new to this forum and am still kind of new to using forums. I have recently bought a new vehicle and have a lot of regular maintenance items to take care of. I heard some say synthetic everything and some say synthetic for some things and not others.
I am also looking for opinions on brands for all items listed. I am planning on keeping this vehicle for a longtime. I am going to put a lot of info below because one thing that I have read from seasoned forum users is "provide more info, list more specifics". Also, I am aware that I may post this in the wrong place and ask questions that are answered often, I have done many searches and am still looking, if you know of a post or thread were there is info I am interested in, please give me a link.
Vehicle Make: Jeep
Year: 2004
Model: Wrangler X - Columbia Edition
Engine: 4.0L AMC Straight Six
Transmission: 5-Speed Manual (NV3550)
Mileage: 86,000
Primary Location: Denver, Colorado
Intended Use: Primary vehicle, on-road 85%, off-road 15%. No rock crawling etc... However, I may use it for occasional towing, but not beyond rated max (3,500 lbs. gross trailer weight).
I do intend to do a three inch suspension lift or 1.5 inch body lift. The recommended tire/wheel size is, 225/75/15 (28.3/8.86/15), I will be changing the tire/wheel combination to 265/75/16 (31.6/10.43/16). This will mean some amount of increased wear which I want to consider in my maintenance schedule and lubricant choices.
Intended Maintenance Schedule:
Every 3,000 miles: Engine oil and filter
Every 15,000 miles: Air Filter
Every 30,000 miles: coolant, both differentials, transfer case, gearbox and spark plugs.
Manufacture Recommendations: (for all lubricants I am looking for thoughts on synthetic vs. mineral)
Fuel: 87 octane
Engine Oil: SAE 10w30, API Certified
Oil Filter: Brand recommendations?
Coolant: Thinking about adding Redline Water Wetter to recommended coolant
Spark Plugs: Any recommendations, other brands or better performing plugs/wires other than the general recommendations?
Gearbox Oil: Recommendations?
Transfer Case: ATF +4
Differentials: I would like to use the same type all the time, I will tow less than 5% of the time.
Front Diff. Regular: SAE 80W-90 API GL5
Front Diff. Towing: SAE 75W-140 Synthetic
Rear Diff.: Manufacture has same recommendations as for the front..
I do like BG products, does anyone have a schedule they like for 44k, MOA, 109 etc...
Thank you everyone for any suggestions or advice you impart.
-Metalcolt
Vehicle Make: Jeep
Year: 2004
Mileage: 86,000
Fuel: 87 octane
-Metalcolt
