New tundra and tacoma sparkplug interval.
Toyota manual says to replace sparkplugs for new tundras with 3.4 turbo and 2.4 turbo tacomas at 40,000 miles. Isn't it too soon for iridium plugs?
From the Tundra warranty and maintenance manual:
Sheesh Toyota... on my old Corolla the plugs are specced for 120k and it takes 15 minutes on my 1.8L.
Are we going forwards or backwards here with the new vehicles? Either way we all can agree taking these things into high mileage is not going to be cheap as it used to be.
One thing that gets forgotten in the number of miles is the average rpm they were subjected to. My 6.0 in my 3/4 ton cruises long at 1800 rpm and accelerating to pass is over at 4500 rpm. The change interval is 100,000 miles. Higher revs and the cylinder pressure of a turbo causes more wear.
Replace them with ruthenium :D
Just need to ensure it doesn't change the replacement interval. On my old Tundra, the change interval for the oem NGK platinum is 100k. I switched to NGK EIX premium iridium because they were supposed to be their premium product at the time, and less expensive than the oem plug. The NGK technical support guy told me they recommend changing them at 40k to 50k. I asked why, and he said they have a finer tip that wears a more quickly. He said the oem spec NGK platinums have a thicker center electrode for longer wear for oem applications and why they cost more to manufacture. Now NGK makes a specific oem spec iridium that is claimed to offer 120k mile life.
So switching to ruthenium, if it has a finer center electrode than the oem plug could mean a shorter replacement interval. Would need to check with NGK tech support.
I think my 2GR-FE anticipates new plugs at 120k. I think that's about when I'll get around to pulling the upper intake to get to the rear bank.
