New transmission screen a little different.
Suburban Washington DC
For a Nissan CVT. A Nissan screen is $35 so I got this AC Delco screen for a Chevy that uses the same Jatco transmission for $20. Any issues using it with the inlet slightly different?
Could be a design change. I'd presume the replacement part is the revised design if this is the case unless the vehicle has had its screen already replaced and the aftermarket one is an older design.
The new one also had curved surfaces while the other is flat.
Hard to tell, but it looks like the new one is positioned more centrally, slightly larger inlet, and slightly lower into the pan(?). Those would all be positives in my book, probably running improvements. Plus, it's AC Delco so my trust index is high. Run it.
The CVT in the Nissan might have a different orientation / inclination angle of the CVT case versus the Chevy installation. I would not use the Chevy filter in the Nissan.
