Here is my atf service plan for our 2013 GS350 which has 60K miles:
Get car up and level.
Drain pan including straw. Expect 2+ quarts to drain.
Put straw and plug back in.
Replace same amount of fluid with Idemitsu WS equivalent.
Run engine for 15 to 20 seconds to circulate atf outta plan.
Repeat 2 more times; last time add perhaps 1/3 quart more fluid.
Run engine until approx. 104* F using ODB2 module and android app.
Switch through gears...
Remove plug until slow stream/dribble.
If nothing comes out I will add about 1/3 quart.
I will repeat every 25 to 30K miles.
