GON
$150 Site Donor 2025
Trav, not sure, I will have to look. Attached is a picture of the hammer my middle Son bought me.Is that the 26oz ball pein? Good hammers.
Troll pawn shopsNew 19mm wrench. It’s one size I don’t have very many of and I use this size all the time so I figured I’d get an extra to keep around and have. Was going to pick up an extra 21mm too but they were all sold out I only have 2 21mm wrenches and one is at home and one at work.
I think you will find that hammer more useful than you ever thought. I use it for all sorts of stuff, I found it just the ticket for separating engine cases instead of leaning on it while trying to hit a piece of wood or brass punch with a hammer.Trav, not sure, I will have to look. Attached is a picture of the hammer my middle Son bought me.
CTA 6500 clutch spring compressor. I need to rebuild a TH350 so we'll see....View attachment 82858
Purchased these extra long ratcheting wrenches to work deep into a dash. Worked wonderful. Reviews suggest these don't work so well breaking big bolts like caliper bolts, but for my use, super happy. I went with this set over the Tekon on because the Tekon extra long wrenches only come in six point. I wanted twelve point for easy on to the hard to reach bolt/ nut.
have a set of 3 dead blow composite hammers - used one today …I think you will find that hammer more useful than you ever thought. I use it for all sorts of stuff, I found it just the ticket for separating engine cases instead of leaning on it while trying to hit a piece of wood or brass punch with a hammer.![]()
I've been looking at tools to start doing my own racing Powerglides. Mostly looking at cheap knock-off tools since I won't be using them often.It works well for TH350, TH400, 4L80E, 4L60E clutch drums using stock return springs, It Does Not work well with High Rate return springs found in high performance shift kits & trans brake kits.
For those you need a Foot Press or a Snap Press.
I use a Hagerty Snapress model# KB-20.
I was wondering...my arbor press is a Dake model 1...it's not ratcheting but has a good bit of Z space....enough to easily fit a full size aerosol can of Brakleen with inches to spare....It works well for TH350, TH400, 4L80E, 4L60E clutch drums using stock return springs, It Does Not work well with High Rate return springs found in high performance shift kits & trans brake kits.
....Anyway, if I had a helper seems one could keep it depressed enough and the other could do the snap ring R&R? From what I've seen the foot press is just to free up your hands?
I have had a much older variant of that for must be 10 years now. Still works great.Bosch 12V 3/8" drill with 5-position articulating head. Comes with a 2.0Ah battery, charger, and soft case. A 3.0Ah battery in the small form factor is also available. This drill is heavier than expected, which is a good thing (unless you are holding it above your head all day). Paid $123 at Amazon.
https://www.amazon.com/Craftsman-Metric-Combination-Wrench-47047/dp/B00DYAGYNKBought these for myself this morning. $93 shipped. 7-18mm.
Also bought a “vintage” US made Mac Tools 19mm for $18 shipped. I can’t think of a better choice on an individually sold wrench. View attachment 83673
