Being the Blazer is from Colorado and not Illinois, Michigan, New York, etc you may have a very nice vehicle. If from a rust belt state, the fuel lines and brake pipe start to fail with nominal salt exposure as low as 60k miles. GM used the lowest quality steel for the brake pipes for these vehicles, almost criminal as most of these vehicles were sold to people in the rust belt, and this design was over 20 years old, and surely GM knew the design could not handle salt.
One example is on the blazer fuel pump, it allows salt to land on top of the fuel pump, but no place for the salt to wash out. SO salt just sits on top of the fuel pump corroding the fuel pipes on top of the pump, the fuel ring that secures the pump to the fuel tank, simply unforegiving arrogance for GM to allow this design. For $20 USD, GM could of designed these Blazers to never have rotted brake and fuel lines, but they screwed their mostly loyal customers, the people of the upper Midwest.
I was a loyal GM buyer since I was 16, but having a complete family driving S10 and Blazers since 1984, through a 2000 Bravada, I learned the GM cared less about its customers and slowly went away from GM, from my observation of the Blazer brake and fuel pipe used. As a comparison, most European auto manufacturers uses a copper nickel blend for their brake pipe, as to mitigate the salt corrosion issues that happen on steel brake pipe. On my 2000 Bravada, after the brake pipe failed at 60k miles, I replaced all the OEM crap steel brake pipe with copper nickel brake pipe.
Replace the fuel pump with a "new design" Delphi. The fuel pump will fail, and they are a pain in the butt to replace. You will want to have a lot of time, and when the tank is empty. You will also want the fuel pump ring removal tool. I would replace this is a summer when you don't need the vehicle.
The front end will need to be greased regularly, if memory serves me correctly 13 zirc points, yes 13.
Finally flush and regularly exchange the coolant. The heater core will also fail and that is a super pain to replace. Keeping the coolant as fresh as possible may help the longevity of the heater core.
