Korry,
Go to "Advance Auto" and pick up two bottles of Redline "SL-1, complete fuel system cleaner"....
Add a full bottle before filling up the tank with fuel and run that tank all the way down. Use the second bottle by adding 2 ounces with each full tank of fuel. It can take several thousand miles to clean combustion chamber and intake valve deposits, so using a lower dose of fuel treat over a long time is more effective than occasional cleanings ....
If you have a high mileage engine, I believe you'll see a difference with the SL-1. I've been testing it in my older Audi and it works as well as the Amsoil Performance Improver which I've been using for over twenty years - it evens smells like the same stuff.
You should notice improved performance by the time that first tank of fuel is half empty ....
Tooslick
www.lubedealer.com/Dixie_Synthetics
Tooslick
