New STP Euro 5W-40
Originally Posted By: MSTUEBER
Autozone finally sent me info on this oil.
Description
STP 5W-40 EURO FS 6/1Q
Inspection Information Test Method Typical Value
Gravity, °API ASTM D287 34.83
Specific Gravity @ 60°F (15.6°C) ASTM D4052 0.8507
Viscosity @ 40°C, cSt ASTM D445 76.77
Viscosity @ 100°C, cSt ASTM D445 12.95
Viscosity Index ASTM D2270 170
Pour Point, °C (°F) ASTM D5950 -45°C (-49°F)
Cold Cranking Simulator at (°C), cP ASTM D5293 5266 (-30)
High Temperature / High Shear Vis at 150°C, cP ASTM D5481 3.7
Noack Volatility, % loss ASTM D6375 10
Color ASTM D1500 2
Zinc, wt. % ASTM D5185 0.102
Phosphorus, wt. % ASTM D5185 0.092
Calcium, wt. % ASTM D5185 0.26
Sulfur, wt. % ASTM D4951 0.19
Boron, wt. % ASTM D5185 0.007
Nitrogen, wt. % ASTM D4629 0.089
Pumping Viscosity at (°C), cP ASTM D4684 28,400 (-35)
TBN, mgKOH/g ASTM D2896 9.8
Claims Information
API SN Approved
API SM Meets Requirements
API SH, SG, SF, SE, SD, SC Meets Requirements
ACEA A3/B3 and A3/B4 Meets Requirements
MB p229.3 / p229.5 Meets Requirements
PSA B71 2296 Meets Requirements
BMW LL-01 Meets Requirements
VW 501 01 / 502 00 / 505 00 Meets Requirements
OPEL GM-LL-B-025 Meets Requirements
Renault 0710 / 0700 Meets Requirements
Porsche A40 Meets Requirements
Thanks for the info! Does look like a very good oil indeed!
If you can find Warren Lubrigold 5W-40 euro synthetic, it has Benz/VW/Audi and BMW LL-01 specs listed on the bottle. I found it at a local family-owned auto parts store for 3.99/qt or $22 for 6 qt case. Been using in some older euro cars that consume oil. Seems to work well for the cost.
Posting an update. I poured in 10 quarts along with installing an S3675ML filter in July before storing my 911.
I normally have some chain slap from the tensioners bleeding down over the months, but the first start was silent and the engine ran smooth as ever, with great hot idle pressure.
Overall pleased.
Overall pleased.
Any reason you switched from Delo aside from this being BITOG and your stash was running low?
Overall pleased.
I ran the Delo 15w40 because it was super cheap on WM clearance. I also wanted to see how a 15w40 would run instead of the usual 0W and 5W-40s.
Felt like giving this STP a shot just because.
So far in this car, I've run:
Castrol 0W-40
Pennzoil 0W-40
Delvac 5W-40
Delo 15w40
STP 5W-40
I've got a bunch of oil on deck, but i keep getting oils for cheap and I like to experiment.
I just bought a bunch of STP HM 10W-40 for $2/qt, so that'll probably be the next few changes.
Overall pleased.
Castrol 0W-40
Pennzoil 0W-40
Delvac 5W-40
Delo 15w40
STP 5W-40
What happened to that big crate of Mobil 1 0w40 ?
Originally Posted by Garak
That's perfectly permissible in a 40 grade, so far.
Thanks! Yea, I misread it as a 30W when it really was a 40W :-(
That's work!
You would never have to worry about oil again brother
looks good! one can wonder how much different same spec oils are! are just feeding $$$$$ the fat cats at sopus + the like, all that advertising + race support comes from buyers paying more $$$$
You'd rather give your money to STP, a company that primarily made it money fleecing people with useless additives? As for SOPUS et al, I do specifically support companies that sponsor racing. I seek that. Note that Red Line has sponsored racing for years, as well.
Let's give it to Redline, so they can invest more money in false advertising.
I just bought their $32 special (5qt/oil with an oil and air filter). I'll be running it in the VW and Hyundai (each being 2.0T). I believe the 5W-40 is a WD product as i've never seen AOC on any of the bottles. That's odd considering AOC is a Florida company. Nothing conclusive though. I've used it in the Hyundai before - no weird noises or vibrations. Ran just fine. Hope the same for the VW. Not running the 508 or 0W-20 anymore - just my choice as i know others really like it and its the correct spec. Like @TiGeo often states, "many of the old VW guard find it difficult to put 0W-20 in an EA888". It's taken almost a year with this Passat to come to this.
Description STP 5W-40 EURO FS 6/1Q Inspection Information
Viscosity @ 40C, cSt ASTM D445 76.77
Viscosity @ 100C, cSt ASTM D445 12.95
Pour Point,C (F) ASTM D5950 -45C (-49F)
Cold Cranking Simulator at (C), cP ASTM D5293 5266 (-30)
High Temperature / High Shear Vis at 150C, cP ASTM D5481 3.7
Noack Volatility, % loss ASTM D6375 10%
Color ASTM D1500 2
Pumping Viscosity at (C), cP ASTM D4684 28,400 (-35)
API SN Plus Approved API SM Meets Requirements API SH, SG, SF, SE, SD, SC
Meets Requirements:
Meets Requirements MB p229.3 / p229.5
Meets Requirements PSA B71 2296
Meets Requirements BMW LL-01
Meets Requirements VW 501 01 / 502 00 / 505 00
Meets Requirements OPEL GM-LL-B-025
Meets Requirements Renault 0710 / 0700
Meets Requirements Porsche A40
Color ASTM D1500 2
Meets Requirements:
Looks really good. Put me in the category of "many of the old VW guard find it difficult to put 0W-20 in an EA888" LOL.
