No difference. At all.Would a plain Jane full synthetic rated at API SQ be as beneficial as a platinum version (Pennzoil Ultra Platinum for example) rated at API SP?
I realize that longevity may be an issue but otherwise?
Thoughts?
The value is that the better oils (even when changing every 5k) will keep your engine cleaner (especially the piston rings)The odd thing is that many people here don't like to run extended intervals. So we're often discussing premium EP oils, but changing them using the same 5,000 mile interval. In that situation, I just don't see the value in going with a more expensive oil. I've been using Magnatec -> GTX -> Edge, but I might switch to Supertech Euro if the price ever makes it worthwhile. I was running 7,000 to 9,000 mile OCI using the premium stuff. But given what I've learned about soot particles and timing chain wear I think the the best thing to do is run something with an appropriate certs and weight and change every 5,000 miles.
That might be true in the case of Valvoline Restore and Protect, but it's the only one I'm aware of that claims to clean rings. Any good quality synthetic should go 5,000 miles without leaving deposits. I've gone much longer and my valvetrain was in excellent condition when I pulled the cover.The value is that the better oils (even when changing every 5k) will keep your engine cleaner (especially the piston rings)
That’s engine dependent though. In some engines an entry level synthetic (and even a mid tier one) changed every 5k isn’t quite enough to keep the rings perfectly clean (hence the reason why many engines end up consuming more oil as they approach 100k)That might be true in the case of Valvoline Restore and Protect, but it's the only one I'm aware of that claims to clean rings. Any good quality synthetic should go 5,000 miles without leaving deposits. I've gone much longer and my valvetrain was in excellent condition when I pulled the cover.
