So I'm going to put on some new rotors. My current pads are only 1/3 worn. The old rotors have some grooves on them. Do I have to put on new pads?
What he said ^^^. Plus use them only if they are square (the same pad depth all the way around). Get some sandpaper & lay it flat on some level concrete with the sand pointing up. Put the pad on the sandpaper facing down. Sand each pad this way turning in circles until all the grooves are out of it. Groovy brake pads may be cool but aren't good for new rotors.quote:
Originally posted by BlazerLT:
I just replaced the rotors on my Cavalier seeing they were warped.
Still had 1/2 the brake pads left so I just swapped on the new rotors and kept on going.
If there is an 1/8 of an inch or less, replace them, if not, I would wait until they wear out so you can get your moneys worth out of them.
