Originally Posted By: KrisZ
How can a complete cooling system overhaul be, you know, complete, without changing the cap when everything else was replaced?
Sorry, I should have been more clear. What I meant to say is that instead of only replacing the cap every two years and replacing other items as-needed, for good preventive maintenance, a complete cooling system overhaul every 10 yr/100k is a good practice.
Hoses, belts, belt tensioners, radiators, thermostats and water pumps can fail at the most inconvenient times (cold weather, trips, summer days, wife driving, etc), so replacing them preemptively is a good idea. Also, for most non-BITOGers, a cooling system failure on the road often results in serious engine damage as the driver often does not stop the engine immediately. $500 in new cooling system components is a lot cheaper than $5000 for a new engine.
On cars with weaker cooling systems, complete cooling system overhauls are common practice. On most late model BMWs, a cooling system overhaul every 75k or so is cheap insurance, even if it costs $1300 to have someone do it:
http://sandiegobmw.wordpress.com/2008/06/06/the-cooling-system-killing-your-bmw/
Even the dealer sells cooling system rebuild kits:
http://www.trademotion.com/partlocator/i...;catalogid=4462
