- Joined
- Apr 24, 2021
- Messages
- 53
Mine too. Saw it Friday and grabbed a jug.My new local Walmart has it in stockView attachment 146720
I would recommend sticking with the grade toyota recommends. We had a 2019 Highlander 3.5L that blew two engines in the first 10k miles. That new hybrid will call for 0W-16.Again, regular Quaker State Ultimate Durability or now Quaker State Full Synthetic has been supar in all my vehicles in signature. When the new 2023 Rav4 Hybrid gets delivered. Will be pairing this with it in 0W20 from the get go.
Does this help any?It would be nice if Quaker state put out the safety sheet showing chemical makeup. I think we would all like to see if any PAO added or something else.
I did Google search. Maybe I didn’t try hard enough. Did what I couldVersion date: 2003?
Eek
Thank You sir. Much appreciatedIf you want to find SDSs and TDSs for Shell products that aren't readily available on their respective marketing webstite you have to use the product catalog search
https://www.epc.shell.com/default.asp?whichLang=EN
We’re you now to find the 5w40? Thank YouMSDS:
10W-30: https://www.epc.shell.com/documentRetrieve.asp?documentId=178762312
5w30: https://www.epc.shell.com/documentRetrieve.asp?documentId=178762252
5W-20: https://www.epc.shell.com/documentRetrieve.asp?documentId=178317655
0W-20: https://www.epc.shell.com/documentRetrieve.asp?documentId=178762192
TDS:
10W-30: https://www.epc.shell.com/documentRetrieve.asp?documentId=175868863
5w30: https://www.epc.shell.com/documentRetrieve.asp?documentId=175868806
5W-20: https://www.epc.shell.com/documentRetrieve.asp?documentId=179763193
0W-20: https://www.epc.shell.com/documentRetrieve.asp?documentId=175868825
5W-40We’re you now to find the 5w40? Thank You
Are you blaming the engine problems on the oil, and specifically the viscosity that you ran? What oil and viscosity did you use in those engines? What were the operating conditions?I would recommend sticking with the grade toyota recommends. We had a 2019 Highlander 3.5L that blew two engines in the first 10k miles. That new hybrid will call for 0W-16.
Interesting all the Ultimate Protection grades specifically say Fischer-Tropsch from 75%-90% while the Euro 5W40 only says Interchangable Low Viscosity Base Oil
Thickies rejoice with that 5w30 viscosity 66.4 @ 40 & 11.7 @ 100. Looks like something I would definitely buy.MSDS:
TDS:
