Quote:
Bill, Mobil is far from the worst. Only recently have they gotten into the "HM" B/S. They have always been great at marketing Mobil 1 because they always based it on performance. Valvoline/SoPUS and others are IMHO much worse than Mobil.
Lets see...
The famous Mobil Drive Clean.
We also had Drive Clean plus.
Then we went to Mobil Clean 5000 (which kept engines cleaner than other oils) and you could run longer than 5000 miles *if* your MFG had longer OCIs or follow OLM.
Oh, wait.. We have Mobil Clean 7500. You can run that 7500 miles. BUT ONLY if your is out of Warrenty or has a MFG OCI of 7500 miles.
Quote- ( Since the Mobil High Endurance Motor Oils exceed industry and car builder requirements, drivers can rest assured that their engine is well protected.
As long as drivers follow the oil-change-interval guidelines set forth in their owner’s manuals, they won’t have to worry about voiding their warranties )
(so follow the MFG OCI which you could do with Mobil Clean 5000)
Also, I did not see this test... Quote again from Mobil (Mobil Clean 5000 and 7500 technology has been tested extensively in various vehicles, under both normal and severe conditions, such as the Las Vegas desert and urban city streets, to prove that the products deliver outstanding performance and protection)
They only had the Mobil 1 Las vegas B S test...
Then we have Mobil 1. Make sure you run it ONLY as long of an OCI as the MFG states or OLM. No longer.
Mobil 1 EP, Now that you can run to 15k only if out of warrenty or if your MFG states you can have an OCI. If the MFG states 5k OCIs, you need to run EP 5k OCI for the warrenty to stay in effect.
Then Mobil 1 HM..
I can wait for Mobil 1 B S oil!
Buster, they all (oil compaines with the exception of Chevron) come up with flavor of the month.
I'm glad I don't fall for it. I just want to protect my engines so they get the best performance, excellent MPG and last a long time.
I've been getting that for the last 30 plus years I've been driving and never had to buy and use Q this or HM, EP that. Or Start up. Or plus..
Just change the oil and drive the car. Works pretty well for me and all the engines that my family have had and run today.
Take care, Bill
