New Pennzoil dino, impressive
New Brunswick, Canada
Hey people,
I used pennzoil platinum, Mobil 1, both in 5w20. I just did my oc and I put in the new SN Pennzoil Conventional that apparently had lots of moly. Suprised how my engine runs better than pp and m1, not a big difference, seems more quiet and rev quickly.
Any of you had good results with Pennzoil conventional?
Its like magik. Cheap Walmart oils have proven themselves to be way better than Full synth.
We all know its true because the Engine just runs better.
Well darn. Now people are going to start talking about how good SuperTech oil is.
The Pennzoil Conventional is good, and I do believe engines run a little better on some oils compared to others. I have found that to be true in all of my vehicles to some extent.
a million folks in here used it or still using some type of Pens. oil. I have used a dozen plus oils in a lifetime so far, they all sounded the same.
I just need to see now if the mileage is the same, and yes, my engine is so smooth, i can feel the diffrence. I will probably stick with Pennzoil conventional with thas SN formula. I think it have around 260 ppm of molybdenum, with is a lot more tyan some expensive synthetic that dont run better.
my Dads been using Pennzoil for 50+ years,darn good oil, i just did a oil change for him on his New ride (2011 Avalanche) so i put in Pennzoil Platinuim 5W30 + AC Delco PF48 oil filter.
Try Pennzoil conventional, you will be pleased
Try Pennzoil Conventional, you will be pleased
I was a fan of pp, but really, Pennzoil Conventional is a [censored] good oil
Pennzoil Conventional is good oil but I'll take my GT1 over Pennzoil Conventional anyday, especially since I can get it cheaper.
yep, Synthetic oils are just marketing, We dont need that since we already know marketing is a lie. Actually all we need is Sweet Crude. [censored] THE TORPEDOS!
I'm anal about my Jeep and I'll testify in court it has run quieter and smoother on Pennzoil conventional than anything else...I think it's the Moly as the moly loaded SM version of Maxlife comes in a very close second, nothing else has been near as quiet as those two. Go moly!
Wonder if i can go longer oci with the same performance on the oil
And what did Pennzoil conventional cost you out on the east cost?
As I mentioned in another thread, when you can get the Toyota 0W-20, a far superior oil, for only $5.70/L (the Cdn price) why would one buy anything else?
