Originally Posted By: zzyzzx
I'd get a junkyard ECM before I would get a new aftermarket one.
According to
these folks that would be a bad idea. They say that the Ford ECMs through 1999 are prone to failure after about 10 years or so many miles so your junkyard ECM will have a lot of years and miles already on it.
The used one my shop put on the Aerostar was only to test if it worked, they bought an ECM from the parts store and I think they went with O'Reilly. Hopefully the next one will last.
Originally Posted By: punisher
Ford assumes owners are stupid. Sometimes jumper cables get hooked up backwards- ECMs have diodes on their power inputs just for this. Voltage spikes happen, like from cheap non spec starter solenoids, alternator diodes fail (AC voltage output), but nothing that will kill an ECM.
Well that is good news, though the site I just linked above says of Ford OBD-1 (1990-1994), that components such as the ECS, the ISC, TPS, engine sensor, alternator or failing batteries can adversely affect the PCM, and that reverse hookup on a battery jump can damage the ECM.
