Well, I have been using SuperTech filters here lately, but really haven't been that impressed with them...sure, the cost is low and they are still construced better than the Fram, but I've been having problems with what I call "sporadic operation...thinking maybe a malfunctioning ADBV".
One day, you'd go out and start it up, and no noise (tick-tick-tick noise of no oil). Next day, you'd go out, and car would make a racket for sometimes a few seconds, and even a few times for maybe a minute.
So with that in mind, and based on a little research, I went over to Advance Auto and picked up a PF52 ACDelco.
First off, as noted by the "weld marks" on the filter, this is definitely not a Champion Labs filter...
Second, the number of holes in the tube looks to be just as much as in the SuperTech filter, but MUCH LARGER.
Lastly...actual use. Vehicle is now quiet as can be every single day on startup (using the same oil as before).
All I can saw, at least juding by construction and actual use, appears a much better filter than the Champion Labs filters.
And guys, if you look up poor college student in the dictionary, you'll see my picture (I just have very generous parents...thank you)...if I can afford a $3/filter, you can too!
Your thoughts?
[ February 10, 2004, 09:23 PM: Message edited by: Jelly ]
Your thoughts?
