Friends, How do you feel about using 5 quarts of any grade of STP Oil + 1 quart of Mystery Marvel Fluid with a new filter as a FLUSH. I'd idle the Jeep (w 200,000 miles) for 6 hours, hence, as per the govts' calculations, have theoretically 'driven' it 300 miles. Id dump it and put in some real primo stuff, such as Mobil 1, Pennzoil Platinum, Motul, Redline, or Royal Purple. I'd use STP because its $3.99 a qt, and would be less w my military discount.
The Jeep has a 6 quart sump. I understand as per the other threads here, "engine flush" are semi-dangerous, and better left alone. I am aware 'a good oil and proper maintenance' keep an engine clean enough but I wanted to put the question to you - most of whom are people I rely on. (I'm looking at you DemarPaint...) Thank you all.
-A
-A
