New Mobil 1 FS 0w-40
Originally Posted By: artificialist
What would happen if you went to a Nissan dealer and observed oil changes? If you saw someone use this in a GT-R, it might be evidence that this is the right stuff.
I'd have an inkling nothing has changed. Imperial Oil is still the service fill here. Of course, Regina just has traffic jams filled with GT-Rs, but I digress.
Originally Posted By: ryanm8
It is one of the highest performance engines on the market though. So the question is, does the new oil just not meet Nissan requirements anymore? I'm not too impressed by it.
Just bcs. it is good engine and car has good performance, does not eman specification is very tough. If we would fallow that logic then we would all use Shell/Pennzoil since Ferrarri use it, or whatever Lambo use it.
I would bet the GTR is harder on oil than Ferrari and Lamborghini's. How many 600hp turbo 6 cylinders are there on the market? I can't even think of another one. And the car is aimed at track use as well.
Bet does not count.
We do not know what are spec. for GT-R, and if there are any. Same is with Ferrari.
600hp 6cyl turbo does not mean anything. It is hp per leter of displacement and that is not indication how hard is engine on oil. It might be as well that it is easier then some 4cyl engines running in normal cars.
Originally Posted By: Falcon_LS
The new version is no longer Nissan GT-R approved either. Wonder what's really different about it - did they just not reapply for approvals to save cost?
It is missing that, and LL-01. I am watching to see if those two come back. The product is new so perhaps there are time constraints that caused those two to not be initially on the product?
I'll be keeping a watchful eye on that. My order of M1 0W-40 from Amazon just came in through the mail, and I got the old stuff.
So is this new version supposed to be replacing the old version or will the two both be part of the lineup now?
robert
robert
The 0w-40 product has been split into two new products and the old product discontinued.
Old product:
Mobil 1 0w-40
New Life 0w-40 in other places
Turbo Diesel 0w-40 also in some of those places
New products:
Mobil 1 FS 0w-40 - Full-SAPS, direct replacement for the old product in most applications
Mobil 1 ESP 0w-40 - Low-SAPS, suitable for LL-04 and other applications calling for low SAPS oils
The new products both have superior low temperature performance to the one they replaced but are, as has already been noted, lighter. However, people need to keep in mind that the new Mobil 1 FS 0w-40 that is GTL based is actually VERY similar in viscosity to the original Mobil 1 0w-40 that was PAO-based. It was the later VISOM (and SN) version(s) that bumped up visc and HTHS.
robert
Old product:
Mobil 1 0w-40
New products:
Mobil 1 ESP 0w40 has been available in Europe for some time, 2 or 3 years?
robert
Old product:
Mobil 1 0w-40
New products:
Yes, but never North America. In bringing it here they appear to have killed off the old M1 0w-40 and replaced it with the "FS" version, which I assume they will continue with globally. I'm curious as to whether they will keep the FS name across the board as well, since its predecessor went by at least three different names depending on the market it was being sold in.
So guys, should the lower HTHS worry me and my M3?
I'm about to change my oil, and I have one 5qt jug of each of the new and old.
For S*%t and giggles, I took a whiff of each oil, the new one has an aroma that you find with ester oil like Motul, old one smells plastic-ky.
No. Your engine calls for HT/HS of 3.5 cP minimum, and the new M1 0w-40 FS is still above that minimum.
I'm anxious to see the new stuff, and hope we see the ESP as well. Even though it's lower SA and "lower" tbn, it's still pretty stout and worth using if you are worried about intake deposits (aka, me)
My local walmart has had 5qt jugs of the new stuff (FS) for some time now. And they also have 1qt bottles of the old stuff, too.
I realize that you are concerned with intake valve deposits, but in the other thread that you started regarding oil for your VW 1.8T, bobbydavro (an obvious industry insider who has a wealth of knowledge and who has responded to people on the forums with nothing but high quality info) said this:
Originally Posted By: bobbydavro
They [Lubrizol] are wrong
Imagine if you could compare a LZ 504 oil to other oils including Mobil 1 0W-40 in the FSi test.
...and this:
Well as 504 is the only spec that needs to pass the FSi test it is very easy to make claims that 504 oils are better for valve deposits. They also need to be low SAPs to pass the VW DPF test.
However this means that other oils dont normally run the test, unless of course you run it for research purposes.
Basically 502 oils would appear to perform very well in the FSi test.
...and this:
In my view SAPs level is not related to the Valve deposits. Additive type, VM and Base oil viscosity/type are more important factors.
Anything with 504 will be good for valve deposits as they have been proven in the VW FSi test, however that's not to say other stuff isn't good / better. I have seen surprisingly good results on 0W-40s
I'd be happy with most 0W-40 A3/B4 oils with VW 502 / 505.
That is one huge "hint" from a technical industry insider. If I owned a DI engine, I'd happily follow his advice as he seems very certain (likely meaning that he's personally seen the proprietary test results that back up his statements).
But anyway, back on topic:
I have no idea why so many people on this thread are concerned about the "lower" HTHS as if it's a problem?
All of the relevant specs that this oil claims (and will claim?) to meet all require an HTHS of >=3.5 cP. Also, as Overkill pointed out, the original pre-visom M1 0W40 had very similar viscometrics, and was a great oil back then. Furthermore, so many people have used and loved GC / BC 0W30, with "only" an HTHS of exactly 3.5, but it has never failed to protect the Euro (and non-Euro) engines that is was installed in over the last decade (or more).
I'd use the new M1 without even thinking twice, and reap the benefits of slightly easier starting/cranking when the weather is really really cold (like it was in previous winters). And we all know how well a GTL base stock can perform in a properly engineered oil.
Good Info here -
I have a Porsche 2004 911 and use Mobil 1 0w40 and used to have a 2005 VW Wagon i used it in.
I now have a new 2016 VW Sportwagen and plan on using it in that.
An independent Porsche garage near me suggested M1 was not very good and that there are better oils but i'm [censored] if i can find any round here - apart from German Castrol.
I know - after i was told that i did a lot of sleuthing on the internet - which ultimately brought me to this site & after much reading came to the conclusion that M1 was pretty good stuff!
Originally Posted By: beetleything
Good Info here -
It's not very good because there's no profit margin for him.....
