What makes you believe it has no VII's?You won't be able to find a more robust motorcycle oil than Mobil 1 10W-40 racing 4t. Shear proof, high HTHS, superb additive package with high ZDDP, no VII's and excellent base oil. Available at WalMart.
HelloJust got a new 2025 Honda CRF250F Dirt Bike for my boy. I don't see any previous posts from users who have this particular model, but I'm looking for recommendations for a good engine oil for it, other than the overly expensive Honda GN4 dino oil. The Amsoil Metric Motorcycle Oil in 10W30 seems possible, but then I've also read that you should run the Honda dino oil for the first few changes before switching to synthetic? So I'm just not sure.
It seems from the research I've done so far that 4-stroke motorcycle oil is different than car/truck oil in that it also doubles as the transmission oil on the dirt bikes (or at least the CRF250F) and automobile oil lacks this extra "whatever" it is, and can make the clutch "slip" if you don't use "motorcycle oil", so not sure about that either.
So any advise from anyone who has a Honda CRF250F Dirt Bike with some experience in this area would be appreciated.
Hello
So what oil you run at the moment in this race machine ?
He didn’t say it was the x model.i confused with the
CRF250RX
what is tri flow ? when you refer chainThat is only a 150 hour motor. Yes 150 hours before rebuild per the book. The race version is 30-35 hours. You are doing yourself a favor by changing oil after every weekend or two tanks of gas and ignoring the schedule in the book. Don’t skimp keeping the oil clear and new. FWIW the main cause of eating up these motors is changing the air filter. No mater how carful you are specs of dirt get in it when you pull it off. The second biggest cause of blowing these motors is cleaning air filters. If any filter says it is washable, especially dry filters on cars, then only replace them. Wait until your air filter is absolutely filthy dirty and then just put a new one on. Like a quarter inch thick of dirt and never clean and reuse. My friend and neihbor is a race mechanic for Kawasaki. You can see him in the backgrounds at races on TV. The other funny thing he taught me is chain lube. It doesn’t matter who the teams are sponsored by none of them use chain lube. They all use tri flow. This from AI:
“”The CRF250F engine typically requires a top-end rebuild around 100-150 hours, depending on riding style and maintenance.Some riders may opt for a rebuild sooner, especially if they race or push the bike hard, or if they notice signs of wear like decreased performance or excessive oil consumption.“”
Well, we decided on Amsoil 10W40 Dirt Bike Full Synthetic. I've always wanted to try Amsoil, so finally did it. We did the first oil change after 5 hours and man did it ever need it! It just glistened and swirled with silver metal when we drained it in to the used oil pan. Those brand new bikes definitely need a short interval for the very first, and maybe the second oil change to get all the manufacturers shavings and such out of there.Hello
On a fresh rebuild on November 2024 on wife's bikeWell, we decided on Amsoil 10W40 Dirt Bike Full Synthetic. I've always wanted to try Amsoil, so finally did it. We did the first oil change after 5 hours and man did it ever need it! It just glistened and swirled with silver metal when we drained it in to the used oil pan. Those brand new bikes definitely need a short interval for the very first, and maybe the second oil change to get all the manufacturers shavings and such out of there.
I have a short video showing how bad it was, but apparently can't upload videos, so here's a screen grab from the video. This was after about 4 hours after getting it brand new.
https://triflowlubricants.com/product/tri-flow-superior-lubricant-aerosol/what is tri flow ? when you refer chain
Hmmm, AI hasn't been on the trails much! I think add a zero, for most of the CRFXXXF bikes for an actual head rebuild, if ever... As a teenager I don't ever recall an air cooled honda bike even burning oil a little? And we've been looking at 10-15 year old ones now and some pretty abused ones still had no blue smoke. I guess this new 250F is 4 valves and maybe have been "improved" to be less durable and gained 2hp, but I think honda would keep these pretty indestructable.That is only a 150 hour motor. Yes 150 hours before rebuild per the book. The race version is 30-35 hours. You are doing yourself a favor by changing oil after every weekend or two tanks of gas and ignoring the schedule in the book. Don’t skimp keeping the oil clear and new. FWIW the main cause of eating up these motors is changing the air filter. No mater how carful you are specs of dirt get in it when you pull it off. The second biggest cause of blowing these motors is cleaning air filters. If any filter says it is washable, especially dry filters on cars, then only replace them. Wait until your air filter is absolutely filthy dirty and then just put a new one on. Like a quarter inch thick of dirt and never clean and reuse. My friend and neihbor is a race mechanic for Kawasaki. You can see him in the backgrounds at races on TV. The other funny thing he taught me is chain lube. It doesn’t matter who the teams are sponsored by none of them use chain lube. They all use tri flow. This from AI:
125 hours at 40 mph is 5000 miles. It's hard to believe that the engine would be worn out at that mileage.Hmmm, AI hasn't been on the trails much! I think add a zero, for most of the CRFXXXF bikes for an actual head rebuild, if ever... As a teenager I don't ever recall an air cooled honda bike even burning oil a little? And we've been looking at 10-15 year old ones now and some pretty abused ones still had no blue smoke. I guess this new 250F is 4 valves and maybe have been "improved" to be less durable and gained 2hp, but I think honda would keep these pretty indestructable.
Valve clearances should be checked on all of them, and 100 hrs sounds like a good interval for the air cooled F models.
