- Joined
- Dec 7, 2012
- Messages
- 3,696
My FIL is building a new house. Pole barn construction, metal roof and siding, 30x50 garage with metal siding on the walls and house 54x32. Basically two pole barns put together.
We wanted to make sure the place had excellent Wi-Fi coverage and a robust network backbone. During the rough-in electrical, he ran two runs of some very nice 23 AWG solid copper CAT6 to:
- all three bedrooms, where wall mounted TVs will be located
- Living Room TV
- Garage/Shop TV
- 2 outdoors access points, front and rear patio
- 2 indoor access points, Living Room ceiling and Hallway ceiling
- Garage/Shop Access Point
- 2 outdoor PoE cameras, front and rear patio
This week I spent some good time installing, terminating, connecting, and configuring the entire infrastructure. This location is being served by a 300 x 10 Mbps Spectrum connection over RG6 copper coax.
- All cable runs were terminated at a 24-port Cable Matters CAT6 patch panel as T568B
- All TV runs were terminated to RJ45 CAT6 keystone jacks as T568B with decorator 2-port plates
- All Access Point and camera runs were terminated to RJ45 CAT6 connectors as T568B
- Every cable run, except the cameras, were ran to a single gang outlet box.
The majority of the cable runs, especially the cameras and access points, at this time, will only utilize one run. I terminated both -- my thoughts, perhaps in the future we'll need LACP or some port aggregation for future bandwidth requirements. However, all of these runs should support 10Gig if needed. The TV areas however, my brain goes to "What if a gaming console, or Xbox/PS". So having two there is handy. Maybe an Apple TV/Streaming Box and a SmartTV? But that'd be redundant. Either way, they're there. Or maybe a spare run if something stupid happens. You never know.
On-to equipment. I am a HUGE fan of Aruba Instant On in home, prosumer, small/medium business arenas. I also love the stupid cheap, power efficient Ubiquiti EdgeRouter X. This was no exception.
- Modem is Spectrum provided. It has a 2.5Gig WAN port on it (which gave me a bee-yatch of a time trying to negotiate gigabit, kept negotiating only 100BaseT).
- Main router/firewall is a Ubiquiti EdgeRouter X configured as a zone-based firewall.
-Four VLANs, management, Home, Camera, and Guest/DMZ.
- Switch is an Aruba Instant On 1830, 24-port switch with 12 of the ports able to supply 802.3at PoE.
-All bedroom drops are turned up with the Home VLAN as the default tag, any un-used port is disabled.
- Indoor and Garage/Shop access points are Aruba Instant On AP22 802.11ax Wi-Fi 6.
- Outdoor access points are Aruba Instant On AP17 802.11ac Wi-Fi 5.
- One Reolink RLN8-410 4K 8 channel NVR.
- Cameras are Reolink RLC-520A in black.
For the interior Access Point installation, I used the usual Aruba combination ceiling tile grid/screw mount and affixed them to blank single gang box wall plates. I have a 1/2" hole drilled to feed the CAT6 cable through. The wall plate is then fastened to the single gang box and the Access Point is connected to its mount.
For the outdoor Access Points, they are mounted in close proximity to the single gang box. I took some metal single gang outdoor weather proof covers and drilled a hole large for a weatherproof RJ45 bulkhead. This was fastened to the plate. The Aruba AP17 comes with a similar RJ45 bulkhead for it's CAT6 connection. Between the weatherproof cover and the AP is a cut-to-length section of direct burial/UV resistant/gel-filled 23AWG CAT6. Then both bulkheads are tightly fastened... and we now have a reliable weatherproof connection.
Camera base mounts are fastened to the eves. They also included some weather proof bulkheads which I fastened onto their cables once installed. However, the cable is pushed back up into the eves, so I am not concerned with any exposure or degradation/cable integrity.
All hardware is on a Vertiv Liebart UPS which should be able to keep the site up for well over 30-45 minutes. The house does have a Generac backup generator so I am truly only concerned with "weathering" the blip, that of which this should do no problem. All cables were thoroughly managed, tied up with velcro ties and secured. I keep looking at the patch panel and switch trying to figure out ways to make it even neater... But I gotta tell myself "It's good enough at some point".
I am very pleased and proud of this build... and happy to do it for my FIL. In my testing, everything performed well. Excellent 5GHz Wi-Fi coverage, indoor and outdoor. Perhaps slightly overkill, but I wanted the home to have excellent 5GHz coverage. Additionally, with metal siding on the interior of the Garage/Shop, and metal siding exterior, I did not want any sort "lets see how it works" and expect coverage from only indoor APs.
Enjoy some pics.
Network rack, patch panel, switch, router, modem and NVR
UPS
Cable management
Living Room AP
Living Room AP closeup
Hallway AP
Hallway AP closeup
Garage/Shop AP
Garage/Shop AP closeup
Front Patio AP
- Living Room TV
- Garage/Shop TV
Enjoy some pics.
UPS
Cable management
Living Room AP
Hallway AP
Hallway AP closeup
Garage/Shop AP
Front Patio AP
