The bulletin from GM sent to dealers on Sept.3rd-'04 states this:
"GM has recently upgraded the Dexron-III ATF specification.
The upgraded specification is referred to as Dexron-III w/ "H-Revision". This upgrade will ensure that ATF's are commercially available to match the quality and durability of current factory-fill ATF. Fluids that meet the requirements of the H-revision are labeled as "Dexron-III,Approved for the H Specification"
Fluids labeled as Dexron-III "H' Specification can be used in any transmission application which specifies the use of Dexron II,IIE or III ATF's."
It does not say anything about it being synthetic or a synthetic blend, anyone know if it is, or why they changed the spec?
Butch 02 Sierra Denali
