quote:
Info - Release of DEXRON VI Automatic Transmission Fluid (ATF) #04-07-30-037A - (Aug 19, 2005)
Release of DEXRON® VI Automatic Transmission Fluid (ATF)
2006 and Prior Cars and Light Duty Trucks
2003-2006 HUMMER H2
2006 HUMMER H3
2005 Saturn Relay
2005 and Prior Saturn L-Series
2005-2006 Saturn ION
2005-2006 Saturn VUE with 4T45-E
2005-2006 Saab 9-7X
Except 2006 and Prior Pontiac Vibe and Torrent
Except 2006 and Prior Chevrolet Aveo, Epica, Equinox, Optra
Except 2005-2006 Pontiac Wave
Except 2003-2005 Saturn ION with CVT or AF23 Only
Except 1991-2002 Saturn S-Series
Except 2006 and Prior Saturn VUE with CVT, AF33 or 5AT (MJ7/MJ8) Transmission Only
This bulletin is being revised to announce the use of DEXRON®-VI with the start of the 2006 model year production.
Please discard Corporate Bulletin Number 04-07-30-037 (Section 07 -- Transmission/Transaxle).
DEXRON®-VI ATF
General Motors Powertrain has recently upgraded to DEXRON®-VI ATF with the start of 2006 vehicle production.
Only 2005 and prior models that currently use DEXRON®-III may use DEXRON®-VI as a replacement.
All 2006 and future models that use DEXRON®-VI are to be serviced with DEXRON®-VI fluid only.
DEXRON®-VI is an improvement over DEXRON®-III in the following area:
DEXRON®-VI
Extended Factory Fill For Life 160,000 km (100,000 mi) For Cars and Light Duty Trucks*
80,000 km (50,000 mi) (Severe Use) For Cars and Light Duty Trucks*
Clutch Friction Stability Improved 100%
Clutch Durability Due To Fluid Improved 120%
Oil Film Thickness Increased 20%
Fluid Oxidation Improved 100%
Foam / Aeration Improved 150%
Shear Stability Improved 200%
* These ATF change intervals remain the same as DEXRON®-III for the time being.
2006 Transmission Fill and Cooler Flushing
Some new applications of the 6L80 six speed transmission will require the use of the J 45096 -- Flushing and Flow Tester to accomplish transmission fluid fill. It is highly recommended that the clean oil reservoir of the machine be purged of DEXRON®-III and filled with DEXRON®-VI.
Parts Information
Part Number Description
88861003 (US) DEXRON®-VI Auto Trans Fluid (1 Quart Bottle)
88861045 (US) DEXRON®-VI Auto Trans Fluid (1 Gallon Bottle)
88861046 (US) DEXRON®-VI Auto Trans Fluid (55 Gallon Drum)
88861004 (CA) DEXRON®-VI Auto Trans Fluid (1 Liter Bottle)
88861043 (CA) DEXRON®-VI Auto Trans Fluid (4 Liter Bottle)
88861044 (CA) DEXRON®-VI Auto Trans Fluid (205 Liter Drum)
