Two weeks ago I bought a new Frontier Crew Cab with the VQ40DE V6 and 5 speed automatic.
It is killing me to change the oil from the factory fill! The manual says that I can run it until the first scheduled OCI (3750 for severe or 7500 normal). I'm planning on running either Pennzoil Conventional or Pennzoil Platinum in the 5w30 flavor with a P1. I'm also planning on doing drain and fills on the transmission since it has a drain plug at regular intervals.
Now my questions:
1) does anyone know what the Nissan FF is on these trucks?
2) when should I change out the FF?
2.5) what OCI would you run? Pennzoil Conventional or Pennzoil Platinum?
3) when should I replace the diff fluid? It specs a 75w-90 syn in the diff.
4) how often should I do the drain and fill on the transmission?
I'm planning on keeping this truck for a while, so I want to take good care of it.
Any help would be greatly appreciated,
Brian
Now my questions:
Brian
