Anyone know anything about the new engine? I heard it uses both DI and MPI.
This is the 1.5L 3 cyl engine. You're referring to the previous 1.5L 4 cyl.how new? I thought this was out in the escape years ago?. and wasnt much better than the 1.6L it replaced.
If you’re referring to the new “Dragon” engine, then yes. Port and Direct injection.
https://ford [QUOTE="pbm, post: 560...Ecosport here in the US...but I am not sure.
There are many claims of significant efficiency gains WHEN deactivating cylinders. Some European manufacturers claim as high as 32% on certain engines. GM claims about 8% on some of it's engines. The gains come largely from reducing pumping losses, as the throttle plate can be opened more, reducing the work the engine has to perform creating a vacuum in the intake manifold.Wow, the article posted mentions it has Cylinder deactivation on a 3 cylinder engine. How much fuel savings is there shutting off 1 cylinder and running on 2?
I would like to hear more about this statement. Firing every 90 degrees for a 4 cylinder, and 120 degrees for a 3 cylinder often relates to the 4 cylinder seeming much more refined and smooth. I have heard nothing but the opposite you suggest, but I'm happy to learn!The good news is that a well designed 3 cylinder engine is often much more pleasant than a droning 4 cylinder.
For a throttle controlled engine - it can be significant.Wow, the article posted mentions it has Cylinder deactivation on a 3 cylinder engine. How much fuel savings is there shutting off 1 cylinder and running on 2?
I would have guessed that Ford's 3 cylinder engine disables all 3 cylinders in a pattern that results in equality. But it seems that they only disable cylinder #1.
If I were to guess, I'd say BSFC improvements by disabling one cylinder are on the order of 5%. Furthermore, it's a small turbocharged engine that works hard, how often do you think 2 cylinder mode will be active?
Reading up on this engine in the Escape, it achieves about 25mpg in real life mixed driving. About exactly the same as my old 1989 Bronco II, or for that matter, exactly the same as Ford's original SUV, the Model T.
If I was only getting 25mpg with a 1.5 three banger I would be disappointed.
Many people dislike the drone of 4 cylinder engines. The 3 cylinder offerings typically have a more unrefined note, but no drone. Many people prefer the sound of 3 cylinder engines, heck even the magazines such as Car n Driver praise the 3 cylinder exhaust note and overall sound as a growl instead of a drone.I would like to hear more about this statement. Firing every 90 degrees for a 4 cylinder, and 120 degrees for a 3 cylinder often relates to the 4 cylinder seeming much more refined and smooth. I have heard nothing but the opposite you suggest, but I'm happy to learn!
Obviously, manufacturers can tune a vehicle to sound good, AND much of it is personal preference. But I've got to admit, the 3 cylinder vehicles I've rented, all had a pleasant growl.
Listen to the Sounds of BMW's New 1.5-liter Twin-Turbo 3-Cylinder Gasoline Engine on a 1-Series | Carscoops
We have heard the claims repeatedly from BMW's people ever since they announced the development of their brand new series of 1.5-liter TwinPowerwww.carscoops.com
Yeah, you are not kidding! There was even a Japanese exhaust manufacturer that can make a normal engine sound like an F1 car! So it's not just inside that car that has "altered sound".Tricky question about the sound. These days you don't know how much comes from the engine, or is faked into the stereo!
