In this TSB, Subaru suggests installing updated control arm bushings will resolve a steering wheel vibration issue. They attribute this to a defect in the material used.
I recently installed Moog front lower control arms on a 2008 Camry. The original Toyota control arms were replaced due to some bushing deterioration, but the vehicle drove fine. An alignment was part of the service.
After the new control arms were installed, when driving at highway speeds above 70 mph, there is a noticeable steering wheel vibration. All fasteners were rechecked, no issues were found. The bushings are not damaged or separated. The only conclusion I can come to is that Moog used a material that is either too stiff (or too soft) for the application. Thoughts?
