New control arm bushing failure after less than a year
Brittany 🇫🇷
Take a look at this. Installed new Febi lower control arms on my Mercedes 11 months ago because the front hydraulic bushings were in really bad shape causing a steering wheel vibration at around 80-90 kmh. I had a long trip ahead and Febi was the only thing available quickly at the time. I drove around 15,000 km since replacement.
Installation was done correctly, everything tightened to factory spec at ride height. One day, a few weeks after overhauling the front end i hear a big clunking sound on the driver side over a speed bump. This might be related to the bushing failure.
I suspect one of the bushings (the worse one) was not installed tight enough inside the control arm at the factory and turned when i heard the noise and has been working under too much tension ever since.
This is just a theory but to me it makes sense. On one of the picture you can see that both bushings are misaligned. I guess this is one more rant about brand parts and that the lesson is always the same: to keep old original semi worn out parts going as long as possible before replacement because the new part will probably be junk unless it is OE.
If anyone around here is still driving a W210, please do not buy Febi lower control arms!
When I re-worked the entire suspension on my 2002 E430 (W210) about 20k miles ago, I used TRW front upper and LCA, a combination of MB and Lemforder rear components and black Bilstein shocks. The subframe bushings may have been Febi or Meyle. All working great.
I've had bad luck with TRW struts, they were doing nothing at all after 15,000 km. At this point i don't feel like dropping too much money on yet another set of control arms but try polyurethane bushings on the lower control arms.
A company called Strongflex makes them for the lower control arms for my car. They make two types, the yellow ones which are harder and best suited for track use and the red ones which are supposed to be softer almost like standard rubber bushings with the advantage of being way more durable.
I'm going for a road trip in germany in a few days and will probably have to keep driving the car with the bad bushing for the next 3000 km and fix it when i come back. I must say that it still drives as it should, i don't think it is internally broken.
Save the old bushing for the hardened inner sleeve and any machine shop can cut you polys from the material of your choice
That said, I'm not convinced the pics reflect a "failed" bushing? That surface cracking is common here but doesn't spell failure any more than wrinkles with age mean your skin has failed.
Those look like deep cracks to me indicating the material has failed. I would not expect to see those types of cracks until 15-20 years of exposure.
I did dorman control arms on my 09 Altima and the alignment shop wouldn’t touch it 2 yrs later. I was dumbfounded that @20k miles, the ball joint boots looked like they were attacked by termites. 50k later and the Napa arms are still like new. I’ve since learned to spray RV rubber protectant on anything that has a boot on all of my cars. My 18 rogue still has the originals @125k and holding steady.
@M104 the general advice is to go with genuine MB rubber components, which will likely last you a lot longer than aftermarket parts. Lemfoerder used to be OE for many parts but they also switched production to China for some. Good luck!
OEM is Best - but I have gotten Good Items from RockAuto.om
There are way to many Fakes - out there today - I was doing 3 Plug Type Test on
Different Turbo Engines : ( Spark Plug Readings ) Whole 9 Yards
1 set came in Odd I Noticed made in Russia , Wait a Min.
Aren't those suppose to be Banded ?
Not Only Banded , but 100% Completely shut Down & Out of Business when Ukraine War
started .. as German Corp had a Branch in Russia ( Iridium Plugs ) - YES Closed Factory 3.5 yrs ago ..
Some How Plugs got Out of Russia and all way to Florida . . After I did My Test - few Embarrassed Folks
Took these Back No Questions Asked . . :coffee:
Lets Buy & Sell ~ Sanction Items - Only in America . .
If quality control is good, that is irrelevant. I had a bunch of name-brand parts made in China, and they are perfectly fine.
Yes, but what if they have enough supply? What are they going to do with it?
OE or Lemforder. TRW is OK if they are the OE supplier of that particular part for that particular vehicle.
That is it! Nothing else!
I have a very bad experience with Lemforder unfortunately. Installed an engine mount that broke when i put the transmission in reverse in my previous Benz. Replaced with OE and everything was fine.
@edyvw are you talking about rubber parts or general metal parts? These control arms have hydraulic bushings, and folks over in MB realm have had only issues with Febi and other rubber parts that are non genuine. Multiple folks with Febi failures on rubber.
I am sure some normal parts, made in China are fine, but not for rubber (e.g flex disks. You want SGF made in Germany)
