Prestone Long Life which is essentially Dex-cool has printed on the container that it meets ford and chrysler specs and actually mentions Zerex G-05 by name as being compatible. Interesting that Prestone would a competitors product by name.
Zerex(Valvoline)also has their own Dex-cool equivalent as well as the G-05. It's not a good idea to mix different types as the anti corrosion components of the mix are not additive in effectiveness. This would lead to premature crudding up of the cooling system. Even though Chrysler (and Ford) coolant is not the same as dex-cool, there really is no reason you can't use Dex-cool equivalents in those vehicles. It may void the warranty ,however. When in doubt ,use Zerex g-05. I just don't believe that there is that much difference in cooling system design and material that dictates that only certain types of A/F can be used.
Chrysler factory fluid is orange and the Zerex G-05 that you buy at the auto store is practically clear. They are infact the same product, with the orange dye being the only difference. Valvoline feels that the clear product is more compatible with existing fluid no matter what it is. Orange mixed with green would be kind of an ugly brown!
Whatever product you use ,don't believe the 5 year 150,000 mile nonsense. Drain and refill with fresh solution every 2 years regardless
Ed
