See my thoughts in red below:
Originally Posted By: skip029
OK 2010_FX4, just got off the phone with a Nissan Tech servicing my area in Western Wisconsin.
Question 1 - What brand of motor oil do you guys use for the oil changes?
Answer - Mobil. [Which Mobil would be nice to know; i.e. Mobil Super 5000, Mobil 1, Mobil 1 ESP]
Question 2 - Why doesn't Nissan recommend using synthetic oil in Turbo charged cars like my Juke? I don't see it anywhere in my owner's manual.
Answer - Synthetic doesn't break down as much but there's a pro and con for using it.
Synthetics trap in more dirt than conventional oil and that oil is going through your turbo also. Synthetics have a higher burn tolerance but the oil change price will be almost double. [Oil filters trap dirt, not the oil. I do not agree with that one. The price is about double for synthetics, but you can find "specials" that will reduce that significantly.]
Question 3 - Do I need to allow the car to cool down (idling 2-3 minutes before shutting off) to prevent oil buildup in the turbo after driving around? I heard that oil can get caught in the turbos and will get coked up inside of them.
I have never heard of such a thing but if that were the case I would think idling may be worse as it isn't getting any air to cool the turbo. Turbo's are designed to already push air and oil through it to help cool down and maintain itself. [I am not sure what type of turbo design is there, but some turbos have cooling lines attached that help cool them. I have never heard that allowing a turbo to idle causes problems, but I have heard that shutting them down without idling may cause issues due to zero oil flow with the turbo still winding down. This may not be the case with modern turbos, I am sure some of the turbo guys here on the forum will add some thoughts here.]
Wow, we don't really get these types of questions. We really hadn't had the Jukes around for that long, so I really can't tell you if the turbo's in them are really good or really bad. Maybe when we get one with 100k miles on it and we tear it up we'll know but so far no one's had issues with them or the engines.
Question 4 - I guess I understand the Juke's haven't been around that long but Nissan's had turbo's before in their 350/370Z's.... They still haven't recommended synthetic oil yet?
Answer - It really does depend on the application for what you are doing with the car. But conventional oil is fine. [Nissan may have designed it so that conventional is fine, but with the heat loads and demands of a turbo, if I were mine I would use a synthetic oil with a good filter, like Mobil, Bosch D+, Purolator P1, or Nissan if it is a good one.]
Well, that is my conversation I had with the man and he was nice. Not saying what he says is 'be all end all' but it is what it is. [He sounds like a nice guy, but I am not certain that he is fully knowledgeable about turbo-charged engines (not that I am, but I have some knowledge).]
