Owen Lucas
$100 Site Donor 2023
- Joined
- Sep 5, 2021
- Messages
- 3,592
How many MPGs is this worth? Have all of the fuel efficiency low hanging fruit have been picked? What’s next, eliminating antennas and side mirrors?
0, it will be offset by some new heavy useless optionHow many MPGs is this worth? Have all of the fuel efficiency low hanging fruit have been picked? What’s next, eliminating antennas and side mirrors?
Since you mentioned it.Regulating emissions of particulates from tires and brake pads is next.
https://www.tiretechnologyinternati...clude-tire-and-brake-emissions-standards.html
https://www.theguardian.com/environ...e-particle-pollution-than-exhausts-tests-show
All the measures they pass end up being paid by someone else. If they want to clean the air, how about dealing with coal rolling school buses, eliminating speed bumps and dips, replace most of the idiotic stop signs with yields, and reduce traffic lights, not have on ramp meters run stupidly etc. No money, got some social agendas to fund.
And while they're at it, fix the roads, no use in having a low rolling resistance tire in potholes.
Pretty much every emission based regulation is hurting MPG.How many MPGs is this worth? Have all of the fuel efficiency low hanging fruit have been picked? What’s next, eliminating antennas and side mirrors?
Actually in New Zealand they do this already, but it seems they have more responsible drivers on average than here.... You can't turn left on a red light though which is annoying.You know, I've long "joked" that a law making stop signs optional (perhaps with the requirement you slow down to 10mph) when no other vehicles or pedestrians are in sight would save more fuel and reduce emissions every year than any of this state's dumb "green" regulations.
CA and WA led the charge on phasing out copper from “ceramic”, non-asbestos organic brake pads. There was an effect on the salmon population. The copper in them didn’t kill the fish but affected the spawning of them - the smaller creeks and larger rivers are also where they spawn and make their way to the pacific. The salmon fishery is a very important recreational/commercial one for the West Coast, especially in Alaska/BC/Washington(commercial) and CA(recreational).Since you mentioned it.
https://www.q13fox.com/news/chemical-in-tire-dust-killing-coho-salmon-scientists-warn
6PPD-quinone is the offender.
And that started way back, when they retarded the ignition in order to increase exhaust gas temperature (due to "lighting the fire late") to improve the effectiveness of the "afterburning" of hydrocarbons by the air injected into the exhaust manifolds by the A.I.R. system; as a result, these engines ran like crap, and an enormous amount of wasted heat energy was transferred through the exhaust port walls into the coolant, causing them to run hot at idle - cylinder pressure fell off, engine temperatures went up, combustion efficiency went down the drain, and fuel economy went down with it.
Okay but air quality in major cities improved correct? There is a benefit of sitting in traffic and not smelling raw fuel coming out of the vehicle in front of you. Especially fuel which contains Tetraethyllead (aka leaded fuel).
Ironically, a lot of the smog in CA / western states is from coal fired power plants in China. Possibly up to 65% of it.Okay but air quality in major cities improved correct? There is a benefit of sitting in traffic and not smelling raw fuel coming out of the vehicle in front of you. Especially fuel which contains Tetraethyllead (aka leaded fuel).
Goes to show how one is able to measure other sources of pollution once you've knocked down domestic emitters.Ironically, a lot of the smog in CA / western states is from coal fired power plants in China. Possibly up to 65% of it.
https://www.npr.org/sections/thetwo...-western-u-s-is-blamed-on-asias-air-pollution
Ironic, yes. They'll probably use a lot more coal to power more of their EVs as they become more popular. There's still no free lunch when it comes to pollution unless everyone is willing to participate in reducing it.Ironically, a lot of the smog in CA / western states is from coal fired power plants in China. Possibly up to 65% of it.
First, this is a proposal for California.What about wanting to put all terrains or mud terrains on something that didn't have them from the factory?
Yea i get load index I usually try to go up slightly if all other options between two different replacement tires are equal. Speed rating I don't 100% agree with, I have and will so long as I am able, buy tires which i feel are appropriate for my application.Haven't heard that one yet. We do have to be very careful of tire load index and speed rating. Anything that goes on the vehicle must me at least the speed rating and load index that the manufacturer specifies or greater.
