Rat407
Yes, mainly in the ICW.Are you in saltwater?
Just got the boat, have the life vests, float cushion, flares and fire extinguisher. No radio but a good idea for sure. The ICW here in the Wilmington NC area is nice and can get busy. Like today, it was empty. Our one hour trip up and then back we saw two boats. Today was holding at 4K for an hour according to the OM.So I assume you have owners manual about maintenance requirements for the boat and engine. Pull the prop grease the prop shaft, mainly so you know how change the prop. You may need a special tool for the prop. A spare prop is a good idea, as are the nuts and washers that hold the prop on. If you are unlikely to hit any rocks with the propeller, then a SS propeller will perform better.
There are USCG requirements for flares, fire extinguisher and life preservers. The sell a USCG approved electric beacon that takes the place of a flare. Using a flare onboard is nasty.
I assume you have a fixed mount VHF radio. If not get one. Also get a floating handheld VHF radio. As a boater, forget about relying on a cell phone for emergency. It's all about VHF radios.
As a boater you should be monitoring VHF channel 16 for fellow boaters needing help.
If you are using a trailer and dunking it in salt water there is maintenance required for the trailer also.
FendersI had a Johnson branded Suzuki 115, great engine. I always kept a couple bumpers on the boat. Have fun.
One of the two happiest days in a boatman's life........Best of luck with it.
Boat fenders, also called bumpers, provide cushion to prevent your boat from hitting the dock or lift.Fenders
And once you leave the dock take in the fenders. Don't go cruising on the water with fenders flying.Fenders
Don't forget a BIG FAT WALLET!Will you trailer or keep in the water?
Bumpers are a must. You'll use them often. I get the cloth covers as they seem to
help with bumper rash. Lots of lines. A good anchor. 1st aid kit. Tool kit. Spare prop.
SeaTow or similar.
