1sttruck, you keep completely ignoring the fact that the older Pentax binocs suited my needs and wants for relatively small carry along binocs. Poor alignment is on what I myself have blamed the worse performance of the new Pentax binocs four pages of mostly useless discussion ago. Check again, just in case you missed that.
You yourself suggested 8x30 binocs. Too large for my needs! They don't fit in my jacket pocket without making me walk around lopsided, okay? Besides, 8x30 binocs have an exit pupil which is only marginally larger at 3.6 mm than is the exit pupil of 7x24 binocs. In terms of sheer bulk, I may as well carry my 7x50 binocs. So, unless you know my pocket size and how much weight I am willing to carry, please don't even as much as guess to figure what binocs I should want in your opinion. Don't tell me what I want.
Regarding precise alignment, don't be ridiculous by making 0.5 mm (You found that figure online, didn't you?
) precision/accuracy/tolerance (take your pick) in mounting prisms seem like an almost unachievable goal. The prisms are commonly dropped into very precisely cast (if "plastic" and often also machined if metal) bases where they are held with flat springs. 0.5, or even 0.1 mm inaccuracy is HUGE in an optical system. This brings me to the reason why I do not ever buy roof prism binoculars, in which prism alignment is even more critical than in a porro prism design. An optical device is generally easily knocked out of alignment, so roof prisms are a no-go for me.
In the pictures below you can see in what fashion a typical prism is mounted. The prism drops into a precisely shaped recessed cutout (see red arrow heads in the picture below), where the prism (see green arrow in picture below) is held in place by a flat spring (see pen pointing at it). Alignment beyond this would require the use of shims. I can't measure what clearance the prism has in it's pre-made cutout, but it's a tight fit -- tight enough for the prism to not fall out if the spring is removed.
My point is, exact prism alignment can be and frequently is achieved simply through excellent fit of parts and careful assembly. With modern manufacturing techniques and materials, bungling something like alignment in an optical system requires quite come carelessness and sloppiness.
I'm done with this thread and I will not further comment, because I know the "discussion" of what my wants and needs should be will continue along with the liberal dispersal of snapped up half truths and outright misinformation until the cows come home and then some. Have a go at it, I don't care!
