- Joined
- Jun 2, 2003
- Messages
- 23,587
About ten years ago I bought a pair of relatively compact rubber-armored, weather resistant and nitrogen-filled 8x24 (7.5° FOV) Pentax binoculars with BAK-4 prism and internal focus. These binocs were made in Japan. They were very well made and rugged with good daylight perfomance, and I have always used them when I didn't want to haul my large Steiner binocs around. These Pentax binoculars (8x24 UCF WR) have been discontinued, but are still available as NOS for around $190, but often for under $90.
I recently wanted to buy another pair of this type of binoculars. After comparing specs and various options, I decided to go with the current Pentax 8x25 (6.2° FOV) UCF WP, which were submersible. Their MSRP is around $150, but I found them for under $70 at Adorama. How could I resist?
I have to say I'm disappointed in what should be a modernized version of the decade old design I have been using. Both binoculars are almost identical in terms of size and weight. The new binocs have a rubber armor that not only feels cheaper and that is thinner, but which is also attached poorly to the polycarbonate shell. The new design allows also easy sand and dirt ingress into the folding mechanism. The optics of the older binocs are far superior with better resolution and better sharpness (tested it on newsprint over 20 meters). I don't know for sure, but I assume that sloppy and careless alignment of prisms and lens elements during assembly is to blame for the inferior optical performance rather than a worse lens design. The new Pentax binocs were made in China.
The only feature that is superior on the new binocs are the extendable twist-and-click eye cups with positive detents. The older binocular has simple, pull-out eye cups, which do work however just fine, and which are probably more reliable in the long run.
So, if you are looking for relatively compact, weather resistant binoculars, I suggest you snap up a pair of "old" Pentax 8x24 UCF WR binocs. Don't buy the new version, which is junk!
End of rant.
End of rant.
