Yeah this. My saturn s-series would "remember" knock retard events at particular throttle openings and RPMs for hundreds of miles. Wiping the battery wiped this memory.Yep, ECM relearn and temporary.
Nope. This isn’t my first oil change! I would have noticed it before.If anything it is the new oil. I notice that on a fresh oil change and my tuned car wants to rev quicker. Happens ever single time. Like I said in an earlier post, I am trashing it coming in for the oil change and am trashing it 20 minutes later to a faster reving car. 95% of the people here will say it’s BS. That’s fine, they can have their opinion, I have mine. It is a micro change but it is plain as day. You soon forget the dirty oil feel and never think about again till the next change.
Only if the battery is absorbing all of the ~1..7kW the alternator can put out---which it won't,either in the scenario LvR explained or with a discharged healthy battery.depends on the engine rpm and the alternator capacity... 120 amps @ 14.4v = 1.7 kW. at 60% efficiency that means nearly 3kW or 4 hp at the crank. If the engine only has 40 hp to give at a certain rpm that's 10% of the total.
above is the output of a 1.8 16V MPi engine, 42 Hp at 2000 RPM. You'll feel 2-4 HP difference.
you're missing the point. there will be no meaningful difference in alternator load or hp drain between the new and old battery, unless the old one was shorted which it wasn't because it still started the car.that's why I said, 2 to 4hp, that's half to full output. And 120 amps is not a big alternator these days....
You have it backwards. A small sample does not represent the large population from which it is drawn. Drawing two batteries that both have shorted cells is much more likely in a small sample than it is in a large sample. Drawing a sample where no batteries have failed cells is also much more likely in a small sample than a large sample. That is the law of small numbers, also called the small number fallacy.Sorry I have to disagree - of all the battery failure mechanisms out there a shorted or partially shorted battery (one or more cells) is just about zero ................ and to have 2 in such a small population is even less likely.
I've seen alternators run hot from old batteries, while normally the load gets shared, the alternator has to do nearly all the work now. When loads go down the batteries charge more. The alternators often struggle to keep the voltage up when batteries are poor.
Like Mightymousetech, I came across this regularly if not often.
Yeah whatever ................. this is turning into a yours is bigger than mine fest as usual so enjoy your ignorance.You have it backwards. A small sample does not represent the large population from which it is drawn. Drawing two batteries that both have shorted cells is much more likely in a small sample than it is in a large sample. Drawing a sample where no batteries have failed cells is also much more likely in a small sample than a large sample. That is the law of small numbers, also called the small number fallacy.
that would mean alternators are normally regulated toI've seen alternators run hot from old batteries, while normally the load gets shared, the alternator has to do nearly all the work now.
That is actually not true. Most newer vehicles won’t even try to charge a fully charged battery. Systems are a lot more complex than that now. The alternator often is not doing anything until the battery is below 60% SOC or similar. So with a new, fully charged battery, the vehicle is likely running completely off battery power, and only charging during deceleration.that would mean alternators are normally regulated to
while different vehicles use different charging schemes, they all rely on the alternator to deliver 100% of the load while the vehicle is running.
and as stated earlier, an old/partially sulfated battery will not draw a meaningful amount of excess charging current unless it is shorted, and that is not the scenario here.
perhaps you are confusing "old" with *severely discharged*. a deeply discharged battery will indeed draw a lot more current... as much as the alternator can deliver. but that will happen with new batteries too, if they are deeply discharged.
welll i'll admit I know nothing of BMWs, but if they really do this it's lunacy. sacrifice a $200 battery to save few cents of fuel? and I've not heard of any american ICE cars doing this. my 2019 toyota doesn't. my wife's 2018 lexus doesn't. i'm not talking EVs here.That is actually not true. Most newer vehicles won’t even try to charge a fully charged battery. Systems are a lot more complex than that now. The alternator often is not doing anything until the battery is below 60% SOC or similar. So with a new, fully charged battery, the vehicle is likely running completely off battery power, and only charging during deceleration.
They are not trying to save the owner on fuel, they are trying to meet some fleet fuel economy value. Saves them money on engineering a more efficient car.welll i'll admit I know nothing of BMWs, but if they really do this it's lunacy. sacrifice a $200 battery to save few cents of fuel? and I've not heard of any american ICE cars doing this. my 2019 toyota doesn't. my wife's 2018 lexus doesn't. i'm not talking EVs here.
Pretty much all cars do this now, this is nothing new. BMW has been doing it since 2006. And why would it "sacrifice" the battery? Both my 2010 3 series and 2013 1 series are still using the original battery without issue. If the battery terminal has an electrical component attached to monitor the charge, it likely does this.welll i'll admit I know nothing of BMWs, but if they really do this it's lunacy. sacrifice a $200 battery to save few cents of fuel? and I've not heard of any american ICE cars doing this. my 2019 toyota doesn't. my wife's 2018 lexus doesn't. i'm not talking EVs here.
Yes ...................... but as usual, not reading the whole thread and understanding what is being said is also slowing you downI am with the alternator drag crowd. When you run a generator to make power at your home it uses energy. Same with a weak battery. I have experienced this phenomenon on VW aircooled motors plenty of times. They had no computer so they knew nothing. When you just have 40HP when new, it can be significant. Sitting and idling in a car with no computer and turn on the headlight and put your foot on the brake and the motor will slow down.
