JR: I have a B&S V-twin, 18.5 hp, about 4 years old. I have successfully used several $3 FL-400S filters, am currenty trying a $6 Wix 51516 with the new Semi Synthetic T03 media. If your engine is the same standard configuration/mounted the same as mine, it will fit fine, just sticks out nearly to the edge of my engine cover. I get so much dust on it every time I run it that worrying about looks would be ludicrous. I use Delvac 1300 15-40 cuz it's often 90+ here. You might want to look at a major brand diesel 10-30 or straight 30 (Delvac, Delo, Rotella) as I doubt it gets hugely hot up there.
Regarding engine break-in: The owners manual and I disagree. (Yes, I'm a fanatic
) They say to take a new, green, virgin, stone-cold engine, and run the pi** out of..excuse me, run it to FULL throttle from minute one, and put a FULL load on it as soon as the engine will take this without dying!
Sounds abusive to me, so FWIW, I did gentle, low speed putzing around the subdivision at lower engine speeds for about a short hour (no blades running), said hi to all my neighbors, and changed out the filter and the metal flake oil. (Use a clean catch pan, and look at the oil in the sun. It will positively sparkle from new wear particles). I then did oil/filter changes at increasing intervals (maybe 3 and 8 hrs, now about every 18-20 with my huge dust). I ran it at a medium speed/one gear lower for my first slow cut, and progressively stepped up the speed to full over the next two 3 hour runs. I always warm it up over several minutes with increasing speed/load. BTW, I burn virtually NO oil, where the manual says to expect one ounce per hour.
Another edit: Running long periods with the blades disengaged may tend to polish up/burn a spot on your blade drive belt. If you drive around like I did, reach under and slip the blade drive belt off for the time being. Good luck.
[ August 26, 2004, 11:27 PM: Message edited by: olddognewtrks ]
