MolaKule
Staff member
New 42-V Automotive Generator's based on Permanent Magnet Rotors.
By MolaKule
The following excerpts are from IEEE Transactions on Energy Conversion, Mihai Comanescu, Ali Keyhani, and Min Dai, Design and Analysis of 42-V Permanent-Magnet Generator for Automotive Applications , Vol. 18, No. 1, pages 107-112, March 2003. These excerpts are for educational purpose only.
"The actual trend in automotive design is to replace some of the mechanic and hydraulic systems with electric systems. As the cost of digital control technology keeps decreasing, the use of of new electric and electronic devices is expected to provide new features and improved performance as well as increased comfort and customer satisfaction."
"The actual power demand in an automobile [today] is in the range of 1.2 to 1.5 kW. The automotive electric system in use for the last 30 years is based on the Lundell machine. This is a three-phase synchronous generator equipped with a field winding and brushes. Its output voltage is applied to an ac/dc converter. The output voltage is controlled by regulating the field current [to the spinning rotor, which creates a changing magnetic flux]….Thus, no control is needed for the converter, a six-diode bridge rectifier. Despite the relatively low performance of the Lundell machine, this system was for many years the best compromise between efficiency and cost."
"With new loads being added to the automotive power system, it is estimated that by 2005 the power demand of a typical car will be in the range of 2.5 to 3 kW. Examples of such loads are electric air conditioners, electric steering systems, electric brakes, or high-energy discharge lamps. At this level of demand, the system based on the Lundell machine becomes inefficient."
"The losses in the alternator are significant and the increased currents require thicker wiring harnesses. The cost of the system increases while the performance drops. Considering the concerned for improved fuel economy and reduced emissions, the need for an electric system with improved efficiency can now be justified with energy savings. With the new [voltage] level of 42-V as standard [system] voltage, automotive companies have started to examine the design of electrical systems and loads to ensure the transition. Various solutions for the future power systems are examined in [references]. Recent advancements in permanent-magnet (PM) materials technology make the PM machine an attractive solution."
Summary by MolaKule:
The new alternator will generate 42-Volts at 75 Amps for a power rating of 3 kV, at 1,800 RPM. The Power Factor is 0.854. The field required by the Permanent Magnets is about 1.6 T. The overall efficiency is a remarkable 90%. There are three phases of power, with each phase displaced by 120 degrees with respect to the other. The alternator has 16 coils per phase (for a total of 48 coils) with two (2) turns per coil. Each conductor is AWG 17 guage wire. Each phase is rectified by a two-diode "full-wave" rectifier system.
The external diameter is 165 mm, the external length is 124 mm.
[ April 25, 2003, 02:09 PM: Message edited by: MolaKule ]
By MolaKule
