Superbuick96
Site Donor 2025
I lurked on this forum but when I saw this thread I had to join! Although my story may not be the worse, its pretty bad.
I inhereted a 2003 Chevy Blazer, I knew that the oil changes and maintainence were not kept up with. And the 4.3 had 76,343 mi. When I recieved the Blazer it was February in N.E. Ohio and temps below freezing, My garage isnt heated so I took it to a Vavoline oil change garage. I told them to change it with conventonal oil, because I wasnt paying the 60-70 dollars the wanted for a Max life blend change. When it warmed up I changed the dino oil with the Max L. blend AC Delco oil filter I bought at the store for 17.00 dollars total. Anyway I found the service records last week. The oil was changed at: 15,232/30,432/48,398 miles. At Chevrolet dealership it was bought at, with whatever conventional oil they use . I received the Blazer at 76k mi. and had the oil changed. So that is around 28,000 miles on a conventional dealership oil. I drained the Vavoline change after 900 miles, it was filthy, and dumped 5 quarts of Max L. So far so good.
