Neglected cooling system, severe rust
I don't know how it got like this, maybe 25 years and never changed, or just ran with straight water? There's like rust flakes inside the thermostat housing. Engine runs great otherwise, no overheating etc. I did several coolant flushes and I guess there isn't really much else to do other than just drive it and consider it a lesson learned buying used cars in the future. Personally I think it's best to just buy a new vehicle and keep it for 15-20 years.
The cooling system is one of those things that's hard to check unless it's dead cold and usually you go look at a car and they already drove it someolwhere or they drove it to work and you're looking at it on their lunch break etc and I'm not about to spray coolant all over someone's engine bay.
You did good. I did the same thing on my iron block cutlass ciera. Just ran water for a day, changed it every day, for a week.
It gets caught in the thermostat because that's a tight spot. Your heater core may have similar issues, might consider a back-flush.
Yeah the heater smells horrible when you turn the heat on. Smells like antifreeze, but I've never had to add any. Probably just needs a new one
Plumbing in a coolant filter between the heater hoses has helped me in the past-my F-450's actually got full of silicate the first couple times I changed it, after I had the radiator boiled out (brass core, severe neglect, no SCAs, etc., etc.)
