To Ursatdx (post #7): What are those pie sections mounted on the wheels?
CTIS. Central Tire Inflation System. Adjust tire pressure on the fly. The pie sections protect the exposed valves.
And greasy, oily residue can be cleaned with Cascade.I use citric acid for wet tumbling of brass, and it does a wonderful job.
Honda has recommended CLR for clogged heater core rejuvenation.
Fleetguard Restore (alkaline) and Restore+ (acid) are cleaners intended to do things...
CLR Pro radiator flush and cleaner. I have 1 gal left over, if you near Bulverde, TX come and get it. Its scary good.It's been a really long time since the car I have had a coolant system flush. It looks like the prior owner ran the wrong/cheap coolant. After many many water flushes it's still brown muddy water.
I'm even looking at potential DIY home recipes if anything like that exists for a cleaning. The car is 24 years old but still cools exceptionally well. I don't have to drive it everyday so even if there's something that works as an overnight thing even. I can do anything
Thanks in advance.
FYI, here is a good write-up with photos on performing a citric acid cooling system flush on a Mercedes Benz diesel:Anybody know the ratio (citric acid to water) to mix?
I'm guessing 2 c. per gallon water.
I bought a 10-pound bag.
I've used it to clean coffee makers/stainless steel thermoses and revived a home humidifier's wick with the stuff.
